[Others] What are those "plus signs"?
How can I avoid adding the three plus signs, shown, that are not part of my design? What are they called? I'm using Ultiboard.
[Others] Is it possible to exceed inputs whilst keeping concurrency?
I'm building something with an arduino nano which uses 8 buttons (digital) and 8 potentiometers (analog). I would like to add more inputs to the build, but need to be able to use multiple inputs a...
[Others] A question: what is the impedance of a resonating LC circuit?
1. Some people say that capacitive reactance cancels out inductive reactance, so the impedance of an LC circuit is 0 Ω to its resonant frequency (not accounting for wire resistance).2. Others say that...
[PCB Prototype] production of a printed circuit board according to a sample
good afternoon. is it possible to make a copy of a printed circuit board from a ready-made sample? small changes will be required to the finished product.I send the sample in the attached photo.if req...
[PCB Prototype] Micro Via cost
How much does using microvia in my board design at to the manufacturing cost?I don't see micro via as an option in the instant quote process.My board is 6 layers, standard 10cm x 20cm.
[Others] IS IT Okay to run 400V on 12A? 7 anode at startup?
I'm playing with a 6AR6 design right now running at 400V B+, and am worried about damaging the 300v max input triodes. The operating point is closer to 150, but ofc they will be exposed to the ful...
7answers
[Others] Can I connect 0.5W speaker with 3W amplifier directly?
I am going to make an arduino project which uses a 0.5W speaker, attached to PAM8403(3W amplifier). Can I directly connect them or should I use a resistor?
[PCB Prototype] Design question on current return path & 0 ohm resistor.
I am designing a 2-layer PCB, the bottom layer is GND and the top layer is signal and power. The PCB has some sensors and an arduino, also the I2C is used.I'm learning but I am confused about how ...
[Others] Can I use a linear regulator together with a boost converter?
Hey guys! I'm making a digital power logger and I was wondering if I should add a linear regulator after a switch-mode converter to make the signal less noisy and more stable or should I stick to ...
