[Others] Some trouble with Opamp circuit
I am buidling this circuit to amplify a signal from a analog sensor. But for some reason, when I build the circuit on a breadboard I get 0v on the output of U1. The output of U2 works fine, so there i...
[PCB Prototype] Guidelines, tutorials
Hello,is there any tutorial or guideline how to prepare board design for your manufacturing?I use Eagle for the design but I do not have an experience with cooperation with manufacturersI would like t...
7answers
[PCB Prototype] PCB motor stator
Hi.I need to build a motor whit pcb stator.The motor must have a 400W powerCan you help me?Regards
[PCB Prototype] What should I do with these ground signals?
Should I link up these ground signals or leave them?PCB I'm working on has a main board and then smaller secondary boards which contain external components. Everything is isolated and has its own ...
[Others] NTC thermistor and fixed resistor, which one has more advantanges?
Both NTC thermistor and fixed resistors can be used for limiting the inrush current. But which has more advantanges in this application?
[PCB Prototype] Adapters SSOP20 to DIL20
Dear sir, I am dr. Campanella Michele form Italy. We will start a project of Modulator/Mhz that we use the LMX2306 or LMX2316 IC (SSOP case 20 pin). Weneed 50/100 pieces of pcb adapters from SSOP20 pi...
[PCB Prototype] I am making a Circular PCB in KiCAD. In the FAQ section it says for Circular PCB something called ' panelized in an array for assembly' is necessary.
I am not sure how to do this panelize thing and also can someone tell me what I need to do for the following PCB Attached here or do I need to panelize at all for my pcb. If I have to do anything like...
