[Others] How to switch on a small load when a applied voltage is removed?
Hello guys, I need to turn on a small DC motor when a applied reference voltage is removed. Do you know a circuit diagram for this or any idea of doing this?
  • answered Oct 27,2020
[Others] Queations about RC oscillators and LC oscillators.
Why RC oscillators are used for generating below 1MHz frequencies, and LC oscillators for above 1MHz freqs? Why cant we use RC for high freqs, and LC for low-medium freqs?
[Others] How to read a 5V ratiometric sensor using a 1.1V fixed vref ADC?
The ACS712 outputs a voltage from 0-5V and the ESP32 ADC reads from 0 to 3.3V using 1.1V as vref. There is a voltage divider already to reduce the 5V to 3.3 range.The problem is: voltage drops on the ...
[Others] "Output Frequency" on a DC switching power supply means the switching frequency of the power supply?
Hi all. The output frequency of this power supply is 20-100kHz. Since its DC out, which would be 0Hz, am I correct to assume that the 20-100kHz would be caused by the switching. So I could in theory u...
[PCB Prototype] hi ..do u have any Megasquirt MS2 bare pcb?
[Others] Can I run a Passive Speaker without an amplifier?
Can I connect a 0.5W Speaker direct to an input (Raspberry pi in my case) and expect it to be as loud as a let's say a phone speaker? Will a very small speaker work directly from an input? If not ...
  • answered Oct 23,2020
[Others] Is there any way to fix it?
Hi all, my mini USB connector somehow broke off the board and has been rattling around its casing, I opened it up and found where its supposed to be connected, is this saveable? could I just solder th...
[PCB Prototype] Dimensity 1000 soc.
Hello, I was wondering if it would be possible to have the Dimensity 1000 system on chip preinstalled to a pcb. I have not seen an option for it and I don't have the time to source the chips and s...
