Hi all. The output frequency of this power supply is 20-100kHz. Since its DC out, which would be 0Hz, am I correct to assume that the 20-100kHz would be caused by the switching. So I could in theory use a low pass LC filter with a cutoff of less than 20 Hz to remove noise? Thanks!
1 | PCBWay Team | 8 |
2 | Frederic | 3 |
3 | Engineer | 1 |
4 | Jegatheesan Soundrapandian | 1 |
