[Others] How to quickly reading GPIO pin LOW/HIGH directly?
I'm expecting to see the state of a pin that I'm reading to pull low for maybe 50 us and then back up to high. The original code running on an UNO/Nano code looks about like this:while ((...
[Others] Relay Output Problem
I'm doing a Sanitiser dispenser with an Ultrasonic Sensor. For every alternate sensing of the hand, I'm getting a brief disturbance signal from the relay. It goes on for a few milliseconds and...
  • answered Oct 15,2020
[Others] The difference between PMSM and BLDC speed control
The speed of the PMSM is controlled by varying the frequency of the three phase signals that go to the motor windings, but the BLDC motor’s speed is controlled by varying the voltage amplitude. Why is...
    by Kemio
[PCB Prototype] bill of materials
do you have a list of components needed
[PCB Assembly] How to replace this USB Type B connector?
The pins have came off from the connector and stuck to the board. Do I simply clean it off using braid, wipe it using alcohol + brush then use a flux pen. Thanks
[PCB Prototype] How to check net antenna for vias not connected to other layers. I use Altium.
I have some vias placed on fills and regions, but the vias themselves are not connected to anything on the other layers. I was expecting that Altium's net antenna rule will show net antenna errors...
[Others] Question on Differential Signaling Pull-up/Pull-down Resistors
For an electronics project I have to implement a differential signaling mode for transmitting data. I'm planning on using some sort of differential driver and receiver IC. Now I was wondering if t...
