[PCB Prototype] mesa boogie schematics
Hello, I have ordered boards for the Mesa Boogie Emulator and I was wondering if I could get a better copy of the schematics for the 3 versions. The ones posted are too grainy to see the values t...
[Others] Question about Highlight all tracks/pads in the same net class.
I'm designing a PCB which is going to have some nets at 100V. I have created a net class "100V" for that and I would like to highlight all pads/lines in this class.I tried doing this so ...
[Others] Room violation in Altium.
All my components show they have violations. When I check them they all state something about a Room Violation. Do I have to have one? Thanks for any help.
[Others] Circuit to route N inputs to N outputs?
Each output must be connected to an input (i.e. input 1 goes to output 3, input 2 goes to output 7, etc), which is why a simple mux wouldn't work. I want to make a "simple" circuit ...
[Others] possibility of pcb production from RS274D Gerbers
Is there the possibility of pcb production from RS274D Gerbers"unfortunatly generated +18 years ago"
[Others] What should i do? Altium automatically removes redundant pads
If I route track to the left pad, the right pad along with the portion of track connecting to it disappears.I think I remember doing something in settings and that issue got resolved, but I forgot wer...
[Others] Any advice on changing an IR receiver to push buttons.
This is an LED driver which controls an LED strip with a remote and can change the colors/intensity of the lights. It supplies 12v to the LEDs.I want to know if it is possible to replace the IR receiv...
  • answered Nov 16,2020
    by DAVIDE
[Others] Do you know how to record a change in value of a analog pin immediately ?
I'm using an arduino and the value in the analog pin needs to be monitored constantly at all points in the program . I’m aware of using a interrupt pin but it will only work when a pin goes high o...
[Others] Is there a type of switch that only have the short press function?
I have a momentary swith wired to a board which has a short press and a long press function. I only need the short press function and I cannot program out the long press one, so I need a hardware solu...
