[PCB Prototype] LED's of 6th anniversary badge
Hello! I have a question.What types of RGB LED's are used on your 6th anniversary badge?I couldn't find these types of LED's and I wanted some flashing RGB LED's for my project...
[PCB Prototype] Coupon Code balance
Hello. I still haven't received the coupon code. Can I get information about it?
[Others] How do I trigger 3 x SCRs in series with a microcontroller without a pulse transformer?
I know ways of triggering a single SCR using a microcontroller pin. How would you go about triggering multiple SCRs in series using a microcontroller since only the last SCR cathode is connected to gr...
7answers
[Others] Could I modify the soft touch switch to always on or bypass it?
I was planning on using a wifi socket to control this dehumidifier only to find out it's touch sensitive switch which defaults to off when plugged into power. Have you met this? Any way to bypass ...
  • answered Nov 05,2020
[PCB Prototype] speakersss
Hi, I saw your youtube video and i was just wondering if there was any smaller type of speaker i could use for this project.
[PCB Prototype] EVO128x32 board
EVO128x32 boardThis PCB came assembled? With components?
[Others] Teensy 4.0 to emulate 27c512 eproms.
Do you think that this board is fast enough to emulate a 28dip 8bit eprom chip without any other peripherals, just read the Adress Pins (16 digital inputs), get the data from the Teensy ram and output...
[PCB Prototype] circular track on pcb
hello pcbwayerplease help me with a query. I want to design a circular pcb and so i have some leds and resistors forming circle on the pcb . but while making the tracks i am confused . is it reco...
