[Others] How to prevent cables from disconnecting from the screw terminals in a relay module
I'm controlling a lamp with a relay module but I'm worried about the cables disconnecting since I'm working with mains electricity and the cables are very easy to disconnect once screwed t...
  • answered Oct 12,2020
[PCB Prototype] Amiga 1200 Expansion Module V5
Do you have an english bom?
[Others] How can I connect to this EEPROM to read it?
Not confident in my ability to de/resolder it (also don't want heat to destroy it) and SMD probes can't grab the tiny pins.
[Others] Does a single supply amplifier only drive a speaker in one direction?
I have a question. The input and output of a single supply amplifier are AC coupled with capacitors.AFAIK the caps just filter the DC component from the signal , they do not magically center the signa...
[PCB Prototype] pin2dmd 128x32 boards
Hello.How much are the pin2dms 128x32 board without the Led panels ?With Elektronik and shipping to Germany .Thank youI have the LED panels. I just need the&nbs...
[Others] Is it possible to effectively ramp the PWM duty cycle to reduce inrush current?
I have some DC motors which I need to power and the power supply can handle the motors (I have a beefy 12V 60A output buck converter which is advertised as having "Short Circuit Protection")...
[Others] Should the ground plane be placed under components to decrease EM radiation?
One question I saw:Should the ground plane be placed under components to decrease EM radiation, as (I think) this will increase the parasitic capacitance and limit the signal rate of the circuit?
[PCB Prototype] What is the function of the track around this PCB?
Is this only to look cool or does having the copper exposed like this add any functionality? It's a PS3 Camera PCB.
