[Others] For PMSM, how is 'field weakening' achieved?
I don't know how the field is actually weakened. For a PMSM motor for example, how can the field be weakened? Is it done through the phase wires or externally?
[PCB Prototype] Do you ship to Bolivia???
Hello, I have a question, do you ship to Bolivia?? I wan to order a pcb circuit from your compani.
[Others] How to measure capacitance using sensors?
Hi all,I don't understand how the capacitance itself can be measured. The dielectric is non-conductive, so it isn't like more current flows whenever the capacitance increases. So, how is capac...
[Others] Why does Capacitors have high resistance in lower frequency?
When having a capacitive circuit powered by AC, you get higher resistance as the frequency gets lower and lower. Why does that happen?Also, does the same thing happen in AC circuits with no capacitanc...
[Others] What stops a boost converter from generating thousand or million of volts?
As far now, the highest voltage I ever seen a boost converter converting is 90V. What stops a boost converter from generating thousand or million of volts?
  • answered Oct 29,2020
[Others] If it will affect conductivityof the circuit if the adhesive gets on any of the component leads?
Hello, I was about to purchase some heat shrink tubing when I noticed they come in plain as well as a dual wall type that has an adhesive/glue layer. My question is whether anyone has found issues wit...
[PCB Prototype] PCB machine features
I wanted to make single side and double sided pcb board. What are the features that I should look for in a pcb machine??like what brand to use, power consumption etc. Can anyone advice..!!
    by Alex C
[Others] Should I connect isolated areas of ground pour?
As it shows, there are two isolated areas of the ground pour. I'm using Eagle, so when I do the pour it does not place in these type of areas unless I explicitly place a via where the bottom...
