[Others] Can I connect more than one Module to the SDA and SDL Port of the Nano?
Hello there, I want to connect a gyrosensor (gy_521 MPU-6050) and a touch sensor (Adafruit MPR121 12-Key Capacitive Touch Sensor) to my nano.I already made a simple mp3 player. I basically want it to ...
  • answered Oct 05,2020
    by Alex C
[PCB Prototype] schematic for dartzeel
Hi, I cant download the schematic, is it possible to allow downloads, i cant read it clearly. If not, do I gain access to it if I order the pcb?Thanks in advance
[PCB Prototype] ECU MP9.0 memory adapter PLCC32 - M27C512 OTP
This adapter is design for a 87C510 DIP28 eprom, but i need the same adapter for a 87PC110 PCC32 eprom !Do you have this adapter or can you make it ?It's the same converter (74HCT573), with same p...
[Others] Do transformers work off of resonance?
Do transformers work off of resonance? I have been told they dont, so why do they work best at one frequency if they DONT use resonance?
[Others] MCU controlled buck converter?
If it's possible to control the power output of a 12V/150W heating element using some sort of buck converter circuit. It should step down the 12V input to various voltages required to vary the out...
[PCB Prototype] what are required for it
please make assemble what are required for it
[PCB Prototype] Como hacer controladores de energía para
Banco de energía con super condensadoresInversor de corriente de 12v y 24v a 110 y 220v con bobina toroidalControlador de energía de vehículo eléctrico Aire acondicionado con celdas de peltier y ...
  • answered Oct 01,2020
