[PCB Assembly] Documentation for THT only board assembly
What are the documentation needed for a turn key THT only pcb assembly?
[PCB Prototype] how to find the same Pcb board
I need this pcb board.It is the battery management board in power bank. I searched but I couldn't get it.
  • answered Sep 03,2020
[Others] How would I connect an old display and commons to ground without shorting them?
I destroyed a clock radio to turn it into something else, and I used a different display that I already knew how to use. Now I'm trying to reuse the old display, and I've found the commons, bu...
  • answered Sep 02,2020
[Others] Can I solder it back on?
While working on ds4 controller this capacitor fell off, is it needed?
    by Kemio
[Others] How do I use a magnetic encoder, and should I use PWM or digitalread to read the angle of the motor at high rpms(2000-3000rpm)?
If say I use AS5048A magnetic encoder, to be able to find the angle at such high rpm, would it still be possible to use PWM? Or do I have to use the digital read? In that case, how would I program it?
[PCB Prototype] Material "copper base"
What means "copper base" ? Is it like an aluminium pcb just with copper or what? Du you have more information about it?
[PCB Prototype] Can anyone help me with this easy circuit board?
Hello. My circuit board got broken and I need to get a new. This part can not longer be bought. It is a tachometer amplifier. It gets the signal from a tachometer sensor (counting the time the engine ...
