[Others] Is this salvageable?
Solder flaked off around a pin and took everything with it. That's the brown substrate underneath.
[Others] Any tricks to soldering
Any tricks to soldering something so small, I’m trying to attach one board to the other and the connections are so tiny I’m butchering in, any help is appreciated. (I' ll be de-soldering in the me...
7answers
[Others] Is there a website where electronic circuits are shared?
I'm looking for a website where i can find some simple or complex electronic circuits to make.
[PCB Prototype] Constant current LED driver
I want to power a constant current LED (145mA & 200mA) at 19-21V.Since this will be powered by Li-ion battery connected to a tp4056, which is the most efficient way to boost the voltage from 3.7V ...
  • answered Aug 12,2020
[Others] When using an NPN transistor for switching does the emitter have to be grounded?
I am trying to control a remote via the gpio pins on a raspberry pi. I don't want to have to use relays because of the space they take up and the mechanical noise. The problem is the pads of the r...
  • answered Aug 11,2020
[Others] Is it ok to switch a high frequency signal with a low frequency transistor?
If you have a high frequency signal, going through the collector - emitter of a general purpose transistor, can you just turn it on/of with a low frequency signal at the base?If you leave the transist...
