[Others] How to create a delay without pausing the code?
I want to make a pin HIGH for a specific duration of time, but I want the code to keep running while the pin is high, how do I do this?
  • answered Aug 05,2020
[PCB Assembly] when will this board be available on Bazaar ?
https://www.pcbway.com/project/shareproject/mXY_Board___Low_Budget_XY_Plotter_Drawing_Robot_Board.html authot said it would be available soon
[Others] Speeduino Compatible EFI Shield
hello!Can I buy pcb forSpeeduino Compatible EFI Shield ?best regard Julian Gonet
[PCB Prototype] inverter 12v to 220v
where can i buy the pcb of inverter 12v to 220v?
  • answered Aug 03,2020
[Others] sbc188 questions
hi, i hope i contacted the right people.I am making an SBC188 and I have some questions to ask because I cannot find documentation on the site.How should the bios "diode resistor" be set?W...
[Others] ordering questions
Hi!I have few question abaout ordering. Mostly assembly based.I want to order 164x10mm PCB with white soldermask, no silkscreen, and with 5 pieces of SK6812RGBW LEDs (SMD5050) and 5 pieces of capa...
[PCB Prototype] Dose separate DC power require for "LIGHT AND MOTION SENSITIVE LAMP" Circuit?
If "LIGHT AND MOTION SENSITIVE LAMP" circuit run by 220VAC then will it automatically power the sensor and relay or separate DC power needs to apply?Why there are two relays in above c...
