[Others] Hdmi splitter on Raspberry PI 3 or 4.
Can I turn 1 HDMI port in 2 with a splitter? on the Raspberry Pi 3 or 4, I know the 4 has 2 outputs. I need about 8. And I don't really want to buy 4 raspberry pi 4s.
  • answered Aug 20,2020
[PCB Prototype] How do i make PCB design from own my project
I have project application. I want to designed it firstly. i m confusing about how do i created layout thus you can product PCB real and send to my country. I am newbe in this design layout PCBWa...
[Others] Do NTC 10K thermistors act like 10K pots?
I'm debugging a circuit and i need to test how the temp changes affect it, but i couldn't get the thermistor needed to test it. I'm wondering if i can use a 10K pot in it's place. Like...
[Others] Do MOSFETs rated for higher current typically have less heat dissipation?
I want to improve the current on one of my inverter circuits, but I don't have larger heat sinks. The current MOSFETs on there are rated for about 10 amps, but I have others that are rated for 50 ...
  • answered Aug 19,2020
[Others] Is there a way to rename power labels?
I am trying to implement a schottky diode (BAT54C) that takes in +5V from the USB connection and +5V from an external source and joins them so that current does not leak backwards into the USB port. I...
[Others] What’s the best way to send a python file from the raspberry pi 3 to raspberry pi 0 for use by the pi 0
I'm looking to share a file from the pi 3 that contains a password to the pi zero that has the key to decrypt. I was thinking about using MQTT or SSH but am unsure of the file sharing aspect. Addi...
  • answered Aug 18,2020
[Others] Could a H-Bridge work with 4 indentical transistors?
I'm curious if it's possible with inverting the input of two FETs? Or connecting the input of the high side FETs and low side FETs on the opposite side of the motor together,is it possible to ...
[Others] How do I wire the led to a power source
Hello, I bought led strip that I plan to connect to a power bank. The strip is rated at 5v and has 144 WS2812B leds. The both sides of the strip have 3 pin connectors and 2 wires for ground and power....
  • answered Aug 17,2020
