[Others] How to connect two PT100 to Raspberry pi?
How to properly connect two PT100 (or similar) temp sensors to raspberry pi. I have been googling and found MAX31865 converter but is it the best option? If im not mistaken both sensors would need own...
  • answered Sep 14,2020
[PCB Prototype] Dolby Pro Logic decoder board for SSM-2126A IC
I'd like to buy 4 Dolby Pro Logic decoder boards for the SSM-2126A chips. Do they come with a parts-list and parts-assembly information? What would be the cost? Please reply : priedel1905@gmail.co...
[PCB Prototype] water level circuit
if I buy this will I get the whole thing with all compponents or it is just the flat board to attatch everything myself?
[PCB Prototype] What is the difference between soft PCB and rigid pcb?
Draw the difference between soft PCB and rigid pcb? What should be paid attention to? What are the specific requirements for processing technology? Thank you!
[Others] Anyone know what is this?
"222" marked on top of it and EF label on the PCB. Found it in a old Casiotone keyboard.
  • answered Sep 11,2020
[PCB Prototype] What is the minimum clearance for trace to via?
I am planning to manufacture 2oz-2layer 1mm FR4 PCB. What is the minimum clearance for trace to via?
[Others] When to use the Autoroute feature in Altium designer ?
When should I choose to use the Autoroute feature in the PCB layout software Altium designer and when should I route by hand? Any experience?
[PCB Assembly] What is this electronic circuit component?
Hi, I came across this when I am attempting to de solder components from an old stereo for parts. I don't know what it is or how to read the rating on it. Is it a resistor? A capacitor?...
