[Others] Will the led driver burn these two led strips If I connect 2 of these led strips to the Led driver(output: 12v 30A)?
The Led driver (output: 12v 30A) and two led strips of 5m each (Input Voltage: 12V DC, Power: 2A 24W).
  • answered Aug 10,2020
[PCB Prototype] i want to make a pcb for a macro keyboard but can't design it
can somebody advise (or if you are so very much kind provide) a pcb with the functions of a 8 by 8 macro keypad and 2 rotary encoders support and using the pro micro to be the brains of the macro keyp...
[Others] Can I use magnet wire to light an LED with an Arduino?
I need to control a really small LED and use the thinnest wire possible so it looks hidden. Magnet wire is very thin and might work but I want to know if I can control an LED with it?
[Others] Rotary encoder keyboard for Hantek PC Scope
Can you please advise on schematic available for a keyboard contaning rotary encoders. This project is for a Hantek 6254 USB PC based Scope.
  • answered Aug 07,2020
    by Jason
[PCB Prototype] Confusion about GND and no net zones.
Hi, I've been designing a keyboard pcb, and I'm a bit confused about GND and no net zones, as in when I should use them( both layers, or just one? Also, should I have isolated copper fills at ...
    by Kemio
[Others] How do I trigger a TIP32C PNP transistor with a 5V output signal from an NE555 IC?
I would like to know how. What voltage does the TIP32C need to make it as a solid state relay. Thanks for any help.
  • answered Aug 06,2020
[Others] Symbol fields are not in the correct place in schematic
Hi all,When I place passive symbols in a schematic the fields, they don't seem to stay where I placed them in the symbol editor and I can't seem to figure out what I'm doing wrong. Has any...
    by Kemio
[Others] Cooling problem---150W boost converter + 100W power LED
I have 12V 10A power supply (PC ) and I use 150W boost converter to raise voltage into 32-35 V (1,5-2A) . I added 15x10cm aluminum plate (5mm thickness , 3 cm fins) to cool LED (thermal paste added).I...
    by Kemio
[Others] Do anyone know how to make this amplifier run on battery
This amp run on 12-24v ac。
