[PCB Prototype] Donations of my shared projects
Why do I not get donations from some of my shar...
[PCB Prototype] Does PCBway program in factory?
Title says it all, will PCBway program the PCB with a provided .hex file?If yes, does this require ISP headder or something else?Thanks.
[PCB Prototype] Is it normal to put multiple power layers on a pcb?
I want to do my first 6 (or more) layer board. If my circuit has a 5v bus and a 3.3v bus, is it normal to have these voltages on separate layers? If so, what is the best way to implement this? ( I am ...
[Others] Original Xbox capacitors.
It looks like all of these have a bulge on the top and obviously the reddish corrosion on top. I read up a little about this problem but I wanted a more professional view.
[Others] Would 1 Watt amplifier will be ruined if I connect a 60Watt speaker to it?
Hi all, I have a portable guitar amplifier (Marshall MS-2) that uses a KIA6213S IC, it comes with a small 8 ohm 0.8W speaker, I've seen people online who plug this little amp to a 12" sp...
[Others] Some problems with my schematics.
I have Values listed in my schematics such as R, G, B, GND etc... but when I load of the netlist it shows it has J1,J2,J3 which are the values too but I want the others. Anyone know how I can change t...
  • answered Aug 14,2020
[Others] Diagonal lines, anything that needs my attention?
When I try to lay out my PCB I sometimes get these diagonal lines going through a component.I click on the component but can't find any details or anything wrong. What does this mean and is it any...
[Others] Would I be able to just glue that back on?
Plastic holding the volume pot on my amp broke. Metal prongs still intact. I wondered would I be able to glue that back on? Thanks.
