[Others] ATM90E26 Breakout
Hi, I want to purchase ATM90E26 what will be a lead time, it will take to reach me at Navi Mumbai ,India
[PCB Prototype] Production of special flexible board
Hello! I am senior technician of the company "Ateko-TM", Valery.We need to produce special flexible doard for our new project.The main board characteristics (mm): Size: 20 x 40 (fo...
[Others] Navigating in "Shared Projects" pages is giving Error.
Hello, Navigating in "Shared Projects" pages is giving Error. I can not navigate page 2,3,4,...
[PCB Assembly] Need PCB board for 2.1 amplifier with bluetooth
Hi team,i want to make 2.1 amplifier with bluetoothso please help me to create PCB as per the below requirementsMy requirements are:200watt output required for two 3 inch 4 ohm 20 watt & 8 in...
[Others] Un-Routed Net Constraint errors
Hi, I have 6 Un-Routed Net Constraint errors, despite that all of them are connected correctly.Things I have tried but did not work:- Reconnecting the pad with the trace- Re-routing the complete trace...
[Others] How can I re-use 74HC165 project without re-draw tracks and re-place component ?
Here's a 74HC165 project,Now I want to re-use this module in others project,As I know that we can use Sheet Symbol, but in PCB we still re-draw tracks and re-place component, it will take a lot of...
[Others] What is this?
Found image of pcb, and can't detrmine, what it does
[Others] Is it possible? Multiple Outputs on 1 Pin?
Is there a way to connect 7 leds to only 1 pin on an arduino and be able to press 7 buttons which turn ON/OFF each of the 7 LEDs individually? I already know how to use an 1 analog pin for multiple in...
