I’ve identified a blown smd cap on a Razer blade 2017. How do I source a replacement when I can’t measure the original and have no schematic?
replacement
blown-smd-cap
Carl
asked Aug 12,2020
replacement
blown-smd-cap
60V,20AMP Supply
I have a schematic but need assistance to generate what PCBWay needs to make a prototype board from it. Where can i go to get assistance?
Procedure for have a board from a github repo made
Silicone mold
I need to design a PCB for a custom gamepad that is compatible with PS5. Which IC should I use for this?
account closure
merhaba kullanılan malzeme listesini paylaşır mısınız
What is the cheapest way of jamming a wifi connection?
SPI surface finish sample card
Custom Ink colors
Delivery to Yemen is available?
PCB Flex heaters
What can I expect regarding lead times on assembly
Small PCB with open cavity
SMD assembly and stock
STK-0050II
Do you sell SPI finish cards?
KiCAD and Multicolor Silkscreen
Aluminum PCB's dielectric layer
Bitaxe hex question
Mason Goebel
