[PCB Prototype] info shipping
I was watching the video "DIY Stream Deck - Button PCB (Open Source Macro Keyboard with LCD Buttons)" and I wanted a couple of information.clicking on add cart will automatically have everyt...
[Others] Should I use GPIO 40 pin header instead of USB?
I have a problem with bumping the usb cable that powers my RPI3B+ and it wiggles out and kills power. I was curious if I could cut off the USB end, solder those two wires to female GPOI connectors and...
[PCB Assembly] Do you offer component warehouse service
HiSome of the components used in our designs are difficult to source and can have very long lead times.Do you have a warehouse service where we could store some component inventory for us to use in fu...
[Others] Why do audio amplifier have volume control and not gain control?
It is always seen that audio amplifier work at fixed gain, while attenuating the signal at the input to change the volume. That doesn't sound good since you decrease signal to noise ratio. Also re...
  • answered Dec 08,2020
[PCB Prototype] Compliance question
Hi there, are you able to produce PCBs to UL 796 standard?Thank you for your help
[Others] Why does current lag voltage in an inductor when opposing EMF relies on current changes?
Why does an inductor cause current to lag voltage? Doesn't a conductor need to have current running through it while it is passed through a magnetic field to produce an opposing EMF?
12answers
[Others] How can I get high audible beeps with buzzer.
Since I've no experience with buzzers, if there are any good ways to choose the right resistor and npn. By the way, I'm using STM32's MCU, supplied with 3V1 to drive a buzzer (GSC4417YA-16...
[PCB Assembly] assemble ttgo tdisplay on another PCB
I have designed a PCB using the ttgo t-display and other components. I have been attaching it to the PCB that you make for me. Can you install this board to my PCB so I don't have to do it later?T...
[Others] Look for the arduino controllable power supply
Hi all, I need to control the speed of a handful of small pumps independently. The speed is directly related to the voltage supplied. I can't really use pwm and the voltage to the pumps must...
