[Others] Is it proper to wire up a decoupling capacitor
Or should I have the track going above both VCC pads and connecting to them in parallel rather than series?
[PCB Prototype] development of board
Can you please tell me if you can order the development of boards for LEDs SMD 3030 and 2835, but I do not have Gerber files and I do not know how to do them. I can tell you the dimensions of the fini...
[Others] Can I use a DC sine wave to drive a single phase induction motor?
I wanted to try building a driver circuit for a small induction motor, using an ATMega328P (i.e. the micro in the Arduino UNO) to generate a 5 kHz PWM signal which changes duty cycle every period usin...
[SMT Stencil] What are the differences and advantages between SMT and THT
What are the differences and advantages between SMT and THT?Which is better, SMT Engineer or molding engineer?
[Others] If it's ok multiple NPN 8050 transistors be used in parallel to increase the maximum amp draw?
All I have are a bunch of 8050s and I want to use them as power switches for driving a DC motor. Since the motor will draw more then the maximum amperage rating for an 8050 I was wondering if I could ...
[Others] Variable inductors are more resistant to mechanical vibration?
It seems that many of the transistor based designs rely on a variable inductor to fine tune all of the resonant circuits in the system, and I am wondering why variable inductors are chosen over variab...
[Others] How to keep good thermal contact? Electrically isolating a heat sink?
I'm making a motor driver board with 4 x BTS7960B motor drivers. I want to put them quite close together and dissipate the heat through some thermal vias and into a heat sink on the opposite side ...
[Others] Request circuit design
Hi . I wanted to design a fortun pro 2 circuit. (Eagle software design) and program software. Of course, I had sent a request before, but it has been deleted. I am waiting for ...
[PCB Prototype] tengo una placa , quiero que hagan una copia
hola mi nombre es Edson Ricaldi. tengo una placa que ustedes lo puedan desarrollar, quiero una copia igual.puedo enviar a ustedes .mi placagracias
[PCB Assembly] How to male CPL file
Hi,I wanted to make a CPL file for you , but I can not find PAD X and PAD Y . I have seen this from your site Designator Footprint  ...
