5
1103
[Others] How to keep good thermal contact? Electrically isolating a heat sink?
I'm making a motor driver board with 4 x BTS7960B motor drivers. I want to put them quite close together and dissipate the heat through some thermal vias and into a heat sink on the opposite side ...
isolate-the-heatsink-electrically
thermal-contact
Jan 13,2021
Nikola Krneta
current constant driver for BI-LED
do you have a shared project on the gpib ar488?
3D Print Size Restraints
supply board for mmwave sensor
PCB Developement
Request for help regarding the use of the "SNES 8MB Lorom/Hirom/ExLorom/Exhirom flashcard with saving feature."
Fertige Boards IV-17 clock & IV-6 clock
Request for quotation: 10 units of Sicherungssucher V2.0 Rev. B – manufacturing, assembly and programming
No Parts cost?
Size Restraints?
Clarification on HDI Via Structure for 6-Layer 1.6 mm PCB with 0.4 mm Pitch BGA
Black Polycarbonate Transparency
wavesshare esp s3
Hi Do you offer wire EDM cutting? Thanks
1.6mm thick PCB via size
Core material in advanced PCB stack-up
ch552e pcbboard
16CH I2C PCB Manufacturing with PCF8575
Lost gerber files (PXL Digital, Hasselt, Belgium)
Would the student funding program from this organization be accepting biomedical engineering projects?
