[PCB Assembly] Need centroid file for your TinyUPS projet
Hi Oleg,I am trying to order your TinyUPS project located here:https://www.pcbway.com/project/shareproject/ATtiny13_TinyUPS_SMD.htmland have it assembled by PCBWay. They need the centroid / pick...
[PCB Prototype] Pull pin security alarm pcb
How to connect the circuit with batteryWhat is the function off all the ground Pull pin security alarmHow to make voltage input on pcbHow to make it rechargeablehttp://Pull pin security alarm
[PCB Prototype] Shipping to india
My PCB cost is coming around 93 dollars.But the issue is for shipping to India, the cost should be more than 100 dollars.
[PCB Prototype] How to control a meanwell driver/dimmer
Hi all, I am looking to hook up a nodemcu to my led driver (meanwell hlg-480-B 3-in-1 dimming fonctions) I have a NPN bc547 transistor from what I've read online this should be enough even tho an ...
[PCB Prototype] material detail
Hi,we have ordered some pcb in past few months before, it was also a flex pcb. our registered id is purchase@kashware.biz,now we are designing a new pcb board, designing is in progress. we need f...
[Others] What are the benefits of using a Schmitt trigger for a switch rather than a simple switch?
The circuit design I'm looking at is using a NAND Schmitt trigger and a p channel enhancement mode mosfet with a tactile switch. What are the benefits of that?
16answers
[PCB Prototype] How should I solder these pins, they are tucked under the chip.
I plan to put solder on a corner pad, place the chip and solder that pin, then do the rest one by one. The problem I foresee is that it's almost impossible to see bridged pins because they're ...
