Hi, I wonder whether I have to calculate impedance controlled microstrips different, when using a two layer flex PCB with a laminated EMI shielding film on top?
You also provide Impedance control as a service under customized options, does that mean you manufacture samples of my design with slightly different track width/spacing to get the impedance dialed in? Or is it simply measured after manufacturing as a form of quality control?
regards
