10answers
[PCB Prototype] How would I desolder these switches?
This remote control, used to control my blinds, and I wanted to replace the buttons (switches?) on it with a relay board controller, so that I could use the remote from a raspberry pi instead of havin...
[Others] Is the use of a optocoupler good for this application?
There is a power source of 75V and I want my Arduino to acknowledge when a switch has been activated. Such as when a switch closes it can read that it has been closed and perform a certain action. Is ...
[Others] Can I power 3 or more sensors only with a 5-Volt pin from an Arduino UNO?
There are 2 line followers, TCS3200, and a Bluetooth module, they are all powered with 5volt source, can I power them all with the 5-v pin in an Arduino Uno? Will it take a lot of current or burn the ...
9answers
[Others] How can I desolder this micro USB connector?
It seems like its bottom place is completely soldered to the board underneath. I am also considering simply wiring a cord straight to the board.
[PCB Prototype] do you have a gerber file viewer that I can use to check my files before placing the orser?
Do you have a Gerber file viewer that I can use to check my files before placing the order?
[Others] Pcbnew is asking me to connect the resistor pads together. Any way to fix it?
I'm using 1206 0Ω resistors as jumpers, I added them in pcbnew not in the eeschema, pcbnew is asking me to connect the resistor pads together! It is a resistor! Any way to fix that?
  • answered Dec 29,2020
    by Irek
[PCB Prototype] Availability
Solar Powered WiFi Weather Station V2.0 Wondering when it will be back in stock
[PCB Prototype] Sw6106 power bank
Can you help me to understand why my pcb works only with usbc connected If leave only the battery it not works ... no 5v as out This is the schema https://pasteboard.co/JChc1yR.png
[Others] How to wire MOSFET transistors when I want to apply a body voltage.
I'm curious where should I apply this voltage? If it will change the threshold voltage, but I can't work out where you would attach a wire to for the body terminal of a MOSFET when they only h...
[PCB Assembly] Part source,
Hi,If I would like to make a PCB assembly with the part : EBC22DCAN-S189from Sullins, is it possible to source the part ? Is the lead time 3 weeks ? What is the unit price for PCBA service ?Thank...
