Is that logical? This PWM stopped working when I connected the three mosfets with single heatsink.
PWM
mosfet
heatsink
Joson
asked Nov 09,2020
PWM
mosfet
heatsink
DJI PHANTOM 4 DRONE
how to search
where is the search page?
Ac motor controller
Eggduino servo problem
andregarcia57
Can you 3D print using PETG?
Frederic
Jegatheesan Soundrapandian
