[PCB Prototype] Can you upload the pcb file
Can you upload the file of the smart speaker with Google assistant + Alexa
  • answered Dec 17,2019
    by Kumar
[PCB Prototype] pcb certificate
can you provide ce or rohs certification for the pcbs?
    by Kumar
[PCB Prototype] remote controller PCB
I need this pcd.how much is Pric...?
    by Kumar
[PCB Prototype] WANT TO BUY
Wanted: Radio Direction Finder to purchase.Please contact me.drkowalenko@gmail.com
[PCB Prototype] Amiga 1200 RTC Module
Hi,Could you tell me what is correct value of C2 capacitor? I found this project on: https://www.amigaworld.de/hardware/amiga-1200-rtc-module/ but I think 10mF is not correct.Regards,Szymon.
[PCB Prototype] Dielectric Constant for specific Laminate type and thickness
I need to design a board with high speed signals like DDR3. I see that its possible to specify what type of laminate to be used. But when specifying the stack-up and the laminate thickness between sig...
[PCB Prototype] why pcbway is not approving project added from shared project
I am adding to my cart project from shared projects .. https://www.pcbway.com/project/shareproject/air_solderin_station_ver__2.html but PCBway staff is telling me Audit FailedFailed re...
[PCB Prototype] Blind vias in PCB quote
Hi, If my design contains blind vias, PCB material option should be "HDI" instead "FR4" in on-line quote?. See picture below:Thanks
[PCB Prototype] Prepare panel of small board
Hello,I want to send you my design. My board is 30mmx40mm. I would like to order a panel. What is the standard suggested panel size where i can utilize the space.Thank youDimitar
[PCB Prototype] Need some baords made.
I have the Eagle file but cant figure out how to export the gerber file that you require.can i email it to you for manifacture?
