[PCB Prototype] esr meter using atmega
hi, is there a programmed chip available for this esr meter?
[PCB Assembly] How to get a XY centroid file with a sprint layout project
Hello I make a PCB project with sprint layout 6.I would PCBWAY build the PCB and assembly the component on it.You claim a XY centroid file but I don't know how to obtain it.Do you have the solutio...
[PCB Prototype] Combining bin files for burning
Hi! A great job! As usual :). A simple question.. How the cad works with the two banks? Do we need to split a 1024 bin file or the software will do it itself? Thanks! It's really a great cart!!
[Others] solar powered wifi weather station v2.0 kit is out of stock.
WHen will the kit for this item be back in stock?Solar Powered WiFi Weather Station V2.0
[PCB Prototype] PCB Manufacturing Time
Hi, we are planning to order several boards which have 1mm thicknes and/or 2 oz copper thickness and/or solder mask colors other than green. How many days is ithe process extended from the regular sch...
[PCB Prototype] My PCB needs a transformer, how do i find a supplier for to include in the BOM ?
Hi,I'm working on a PCB that will be powred throuth a 220VAC, i'm stepping down the 220v to 12v then to 5v throuth a step down transformer and a voltage regulator.the 5v needed to power the mi...
[PCB Prototype] 4 layer lead time
What is your current lead time for prototype 4 layer ENIG PCBs and Stencils?Thanks
[PCB Prototype] Copper core PCB
Hello,For the PCB prototyping, can you do the copper core PCB with "direct thermal path", i.e., no dielectric layer under the thermal pads? If you can ,how the price is calculated? Thank you...
[PCB Prototype] Bug of your web site
I just noticed that there was an error on your site.Customer Uploads two separate PCB order files to the system. Prices are determined.The price of the cargo is taken for the first PCB, and the second...
[PCB Prototype] Is 6 layer PCB still available for ordering?
Hello, I've placed an order for a 6 layer board (ENIG) and a stencil for it. I've saw that production has resumed at about half capacity after 10th of February. Is this valid for 4-6 laye...
