[PCB Prototype] 200Watt amplifier TDA7294
Hello,I have download files for that amplifier TDA7294. Board is beautifull designed.Please can you help me with holes for TDA7294? holes needs to be bigger 0,2mm on diameter. TDA doesn t fit ot...
[PCB Prototype] Tapuino source code
Hi Damian,I want to purchase a couple tapuino pcbs but before I do I want to know if the source code is available, the current link is 404 unfortunately.Best regardsStephen
[PCB Prototype] pcbway declined (failed to review) gerber
there is a shared project GALAKSIJA PLUShttps://www.pcbway.com/project/shareproject/GALAKSIJA_PLUS.htmlpcbway declined (failed to review) gerber , but other pcb makers are accepting them wha...
  • answered Jan 11,2020
    by LOTEC
[PCB Prototype] DIY universal pcb
Hello.I need a DIY universal double sided protoboard, (both sides identicle). It needs to be 260mm X 25mm with a 3mm drill hole on each corner. So basically the standard protoboard but the size I requ...
  • answered Jan 10,2020
    by Hrach
[PCB Prototype] looking for PCB universal wireless phone charger.
I don't know PCB design, but I like to buy ready to use PCB, where I can connect coil and charge phone,if you have, please help me.Shawn.shroff@gmail.comReadymade PCB for a wireless phone ch...
8answers
[PCB Prototype] Can you make inverter 3.7v to 220v with 200Watt.
I will like to know if you can make inverter with 3.7v to 220v with 200Watt.
[Others] Mixed material PCB layer stack-up
I would like to knwo if PCBway does mixed material PCBs. I mean, can the layer stack-up for example be such that some of the layers use standard FR-4 as a dielectric and some of the layers use Rogers ...
[PCB Prototype] Motorcycle fingerprint
Hi, I'm from Bangladesh. I seen your video on YouTube. It is very guineas creation. I want to order not only PCB, I want to order all things in one box the things you've used for (motorcycle f...
[PCB Assembly] Need to see PCBWay parts library
Hello!I am interested to order soon one sample order and one bigger order for PCB manufacture + SMT assmbly.I need to check your SMT parts library to see, if you have on stock parts required.Actually ...
