[Others] Can someone help\ Allegro.
Someone please help me fix this, I don't know where to find it. I use Allegro
  • answered Jun 25,2020
[Others] Trouble about placing the etch shape.
Hi guys, I'm new in Orcad. I met a trouble when place the etch shape (The PCB on the right). It override anything. The following PCB I drew at defferent time.
  • answered Jun 23,2020
[PCB Assembly] Can I place some components under the via IC on the other side of the PCB.
Hello, I have two through-hole ICs used with SMD components, and my main purpose is to reduce the size of the layout. Can I place some capacitors and some components on the under portion of the throug...
[PCB Assembly] Can anyone help? To ground the centre pad of the IC.
Hi,Can anyone help me out to rectify this error. I need to ground the centre pad of the IC, as tried of placing a via in the centre pad, and grounding it but I am facing this error. Thanks in advance.
  • answered Jun 22,2020
[PCB Prototype] Project Quote
Hi!, Im from Argentina. I must produce and assembly 100 pcs of 40mmx40mm PCBs single layer FR4. I'd like to know about the process of assemblying , how to proceed with the component list, and abou...
[Others] Payment through Aliexpress
Dear sirs,Are you still receiving payment through Aliexpress?ThanksJose Maia
[PCB Prototype] PCBway 2020 capabilities
can you please provide me with the current capabilities for 2020.minimum via, microvia, ratios, pitch, widths, etc.
[Others] Applying the post for designing engineer.
Dear Hiring team, Hello everyone ,i wish to apply for the post PCB Designing Engineer.I have more 2 year eperience in Electronics EMS industry. Saw your web portal and youtube video...
[Others] Tracks end too close??
Hi, For some reason, KiCad is claiming that these three tracks end too close to each other and also to a via, all in this one spot. But there is no via there.Is this a bug? There are four &...
  • answered Jun 19,2020
[PCB Prototype] double sided aluminium PCB
Hello,I would like to know some information about capabilities of double sided aluminium PCBs with both core in the middle and on the bottom.What is the stackup for these configurations (especially fo...
