12answers
[PCB Prototype] Gerber file problem
I have a project but I don't have a Gerber file. I don't have a professional program for Gerber files. I have a DXP file. Is there any program that converts DXP to Gerber? I use DesingSpark an...
[PCB Prototype] Depanelization using CNC
Hello,I have a question related to routing. I want to make a routing program in CAM350 for removing the mill tabs in the manufacturing process. The process should go like this:The machine routs the PC...
[PCB Prototype] Need pcb design to have mini relays with esp32s chip and hilink ac to dc converter
I need pcb design to have Hilink ac to dc converter with ESP32s and mini/micro relay (2ch/4ch/8ch) and it should work similar to sonoff 4CH R2 relay. Is it possible to have everything on single pcb so...
[PCB Prototype] Surface Finish: ENEPIG
Hi!Could you please clarify the following questions:1. What layer in Eagle should I use, to have ENEPIG finish be applied to my board?2. If I don't need Silkscreen, will you aplly Surface Finish e...
[Others] DIY Solar Lamp Kit V2.0 || Easy School Science Project || STEAM Education Kit
Hello,I just saw your amazing prototype lighting device that is based only on solar PV. i was wondering if you do sell any prebuild protoype that which i can purchase as i need it for education purpos...
[PCB Prototype] Buying flex PCB without design, empty design
Dear SellerIs it possible to buy clear flex PCB?Best regardsAndrej Radulovic
[PCB Assembly] Component Placement Requirements: minimum distances?
Goodmorning,is there available table or suggested values for minimum distances among SMD/PTH packages?SMT/PTH device spacing depends from technology and assembling equipment, I would like to make PCB ...
[PCB Prototype] Altium 10: How to specify break away notch in Altium between 3 different board in 50x100mm board
I have Altium 10Which layer to specify 3 board to have break away notch?These 3 boards has same size but different circuit.What clearance between two board (0.5mm each side?) and edge (0,5mm)?Thanks
[PCB Prototype] 8 Layer Stackup with 3 Inner Signal Layer
Hicould you please suggest me 8 Layer Stackup with 3 inner signal layer?i need impedance control (50 ohm single ended and 90-100 ohm on differential trace)
