[PCB Prototype] Hey! I have written a pretty long project description for sponsorship, and my text was cut in half :(
[PCB Prototype] integrating KA 13DY potter and brunfield relay
hi,can you tell me cost to modify your PCB for connecting TYCO KA 13DY relay ? we have stock of those components and i would like to offer my customers this relay integrating your PCB controller with ...
[PCB Prototype] How do I know which oz of Cu to select in the "Finished Copper" section? I have no idea how much Cu is needed to build my pcb.
How do I know which oz of Cu to select in the "Finished Copper" section?I have no idea how much Cu is needed to build my pcb.
[PCB Prototype] Drawing format?
In what format does a schematic have to be to be used to make PCB. Would a hand drawn one be OK
[PCB Prototype] Gerbers or project for Commodore 64 128 S-Video AUDIO jack RF modulator bypass replacement
HiCould you share the gerbers or project for "Commodore 64 128 S-Video AUDIO jack RF modulator bypass replacement", I asked becouse I would like to improve RF path and power ground loop on PCB, the pr...
[PCB Prototype] Mag echo keeley clone
Hi, I just made a Mag echo from the geerber you shared. Recently, I found it noisy and hissing when turning the potentiometers. And on the circuit, there is a missing 10uf capacitor to make the LFO le...
[PCB Prototype] second opinion
Hi, do you offer design consultancy, more specifically a second opinion for a prototype board?
[PCB Design] Suggestion for 300 um pitch BGA
HiWe need to design a PCB with a 300um pitch BGA component. Please have a look at the attached image showing the footprint of the component.Question:What approach do you suggest to fan out all signals...
[PCB Design] AD20 Study Notes 2/3
16. Object class manager: DCDC, here you can add the class of PWR, and add the power supply VCC, GND into the member list. Back to the PCB, the top layer to the bottom layer28. CrystalCrys...
1 ... 71 72 73 74 75 76 77 78 79 80 81 ...
