Hi, can you make these prototype watch parts (2–5 of each, STEP files available)?
- Gears: brass, ?2.5–9 mm, 0.12–0.25 mm thick, module ~0.06–0.12: ±0.01 mm (ideal ±0.005)
- Escape wheel: steel, ?2.6 mm, 0.15 mm thick: ±0.006 mm (ideal ±0.003)
- Pinions with shaft: hardened steel, ?0.5–1.4 mm, up to 4.3 mm long: teeth ±0.008 mm (ideal ±0.004)
- Staffs and pinion pivots: hardened steel, polished, ?0.14–0.20 mm: +0/-0.004 mm (ideal +0/-0.002)
- Balance wheel: brass or CuBe, ?6.3 × 0.5 mm: runout 0.02 mm (ideal 0.01), bore ?0.20 ±0.003 mm
Which of these can you make, to what tolerance, and at roughly what price and lead time?
Thanks
