Hello everyone!I have done a layout of a small PCB. Now for a automatic assembly I need to replicate it (put 12 same small PCBs on one big PCB). What is the best way to achieve this in circuit studio?...
I was advised to clean PCB using petrol if alcohol is not available. I tested and found that Petrol and alcohol both works good on PCBs. I have also tried with acetone but it makes white spots on PCB....
I like pcbway very much, but I think there are still some problems that need to be improved to promote pcbway's promotion, so I came up with a question that hopes to attract official attention to ...
Hi, Can't figure out how to select multiple text objects in PCB editor. Is this possible to do directly? Utlimately I was trying to do this so that I could reduce the silkscreen si...
