[PCB Assembly] Do you offer pre-flashing service for ESP32 modules with our custom firmware?
Hello,We are planning to assemble around 100 units of a product that uses the ESP32 module. Do you offer a flashing or pre-programming service where you can upload our custom firmware to the ESP32 mod...
[PCB Prototype] 2-Layer Stack-up Breakdown
What does the stack-up look like for a 2-layer 1.6mm thick board?
[3D Printing] Sega NOMAD shell
Roughly how much did this NOMAD shell cost?, looks amazing
[CNC Machining] Low tolerance borehole in machined part
I'm looking to create a part with a very precise borehole with a radius of 3.2316 mm. The Goal here would be 1/100 mm tolerance or even better 1/1000 mm, depending on possibility and pricing. I was ju...
[Others] Official Bat Detector USB Microphone v2
I’m trying to find “Official Bat Detector UCB Microphone v2” (first hit if you search for “bat detector”). I get an error if I try to go to that link. The URLis https://www.pcbway.com/project/sharep...
[Components] Verification if you can Procure Certain USB-C Connector
I would like to ask if you will be able to procure one of the following USB-C connectors, as I want you to assemble them in a future project:https://www.digikey.com/en/products/detail/assmann-wsw-comp...
[PCB Prototype] High-Temperature PCB Materials
Hi,I'm looking to design PCBs that can withstand oven temperatures up to 250 °C for over a week. I checked your website and found that the highest Tg available is 185 °C. Do you offer materials suitab...
[Others] i have a question about a plug
HI Do you have this in EU plug ?
[PCB Prototype] How to order share pcb project?
I want to order the pcb on the following link:but I don't know the following specifications:- dimensions- layers- tickness- materialCan I be helped? thank you for your attention and assistance.Warm re...
1 ... 63 64 65 66 67 68 69 70 71 72 73 ...
