Cold Solder Joint / Soldering Defects
sheng wang asked May 06,2025
The solder does not properly wet the pad or component leads, leading to poor contact, which may cause intermittent or complete circuit failure.
Solution: Increase the soldering temperature or prolong the soldering time to ensure good contact between the component and the pad. For more PCB solutions: Censtry PCB Assembly
  • Your Answer(0)
