Hi PCBWay,
I’ve designed a stainless steel 316 plate that I’d like to have laser cut and then chrome plated. I also noticed that you offer a laser engraving option.
My question is regarding the files I need to upload. When I select the laser engraving option, it asks me to upload a technical drawing.
Should I upload:
A 2D top view of the part showing the engraving details/locations as the technical drawing; and
The original 2D file of the part without the engraving as the main cutting file?
Or do you require the engraving and cutting information in a different file format or setup?
I just want to make sure I provide the correct files so the part is cut and engraved exactly as intended.
Thank you!
