2answers
[Others] Can the output voltage of an opamp damage the opamp if it is amplified to a level beyond either of the supply rails?
If I am making a differential amplifier (for example) with both input voltages within the limits - if the output signal is amplified beyond either of the rail voltages (<Vee or >Vcc) would this ...
