Z-axis milling in PCB
Javier asked Jan 23,2026
I would like to know if it is possible to make PCBs with z-axis milling, and if it is possible, how to specify areas. In the attached example, see that we need to make a pcb similar to a "frame" and that the interior area (signaled in yellow) needs to be milled for smaller thicknes.
How do we specify that in the gerbers?
Thanks
