HackberryPi CM5 Shell questions
Engineer asked Sep 29,2025
Hello,
When filling out the form for the front covers, the tapping threads section asks to upload a technical drawing. The section below that also asks about inserts, and also asks for a technical drawing. Do you recommend inserts for the M2s? What technical drawing are they asking for? How did you get around this part?
Also, for the middle part, the dimensions are slightly different than the antenna mod STL with power switch protection from a different site. Have you tried the antenna mod STL and would the dimensions for that version need to be changed or does it go well with the front and back of this?
Thank you.
  • Your Answer(2)
    1 PCBWay Team 5
    2 Engineer 2
    3 Engineer 1
    4 sheng wang 1
