hi
are you able to create a stainless steel shaft for an electric brushless motor that needs to start at 4mm diameter and a straight step down to 3mm, and about 100mm long ?
example...the first 75mm is diameter 4mm and the remaining 25mm is 3mm,
thanks Terry
