Inquiry: PCB Reverse Engineering, Schematic Extraction & PCBA Prototyping Services
Engineer asked Sep 22,2026
Dear Sales & Engineering Team,
I am looking for a reliable partner to perform Reverse Engineering on a physical PCB sample and provide full turn-key PCBA prototyping.
Project Details & Requirements:
PCB Reverse Engineering:
Extract PCB Gerber files (Layer stack-up, trace routing).
Generate complete Schematic Diagram.
Generate Bill of Materials (BOM) with exact component identification.
Firmware / IC Readout:
Check and extract firmware if any programmable ICs are present on the board.
Prototyping & Assembly:
Fabricate 5 units of prototype PCBs (PCBA) based on the reverse-engineered design to verify functional correctness.
Please find attached high-resolution photos of the top and bottom sides of the PCB module for your initial evaluation.
Could you please provide:
An estimated quotation for:
Reverse Engineering (Gerber + Schematic + BOM)
Prototype Production (5 pcs fully assembled PCBA)
Estimated lead time for the entire process.
Instructions on shipping our physical sample to your laboratory in China.
  • Your Answer(3)
