2answers
[PCB Prototype] SHipping cost to usa
Hello. Wanted to know the shipping cost to USA ( and approx how long it takes). This is for 5 pcs from your community boards ( speeduino v 0.3). THank you.
1answers
[Sheet Metal] Threaded inserts specifications.
I want to add metric M3 threaded inserts to my 1.5 mm mild steel metal sheet design, and i need the insert to be fairly flush with the metal sheet surface while protruding on the other side by no more...
1answers
[PCB Prototype] Other RF materials besides Rogers
If needed can PCBWay acquire other RF materials from different vendors other than Rogers?
1answers
[PCB Prototype] Small PCB with open cavity
What are the principles of open cavity PCB design? What are the cavity size and PCB dimension requirements?
0answers
[Others] Any el84 se/pp project.
Does anyone have a project or schematic diagram of el84 se/pp?
1answers
[3D Printing] Silicone mold
Hi I saw you are making silicone mold in order to do vacuum casting. My question is : I have design for a master mold, I would like to know if it will be possible to 3Dprint the design and also pour t...
1answers
[PCB Prototype] Procedure for have a board from a github repo made
Hi:There is a Github repo for a board I would like to have produced. I'm definitely a newbieWhat is the process I need to follow to get it made?
0answers
[PCB Prototype] I need to design a PCB for a custom gamepad that is compatible with PS5. Which IC should I use for this?
1answers
[PCB Prototype] account closure
how do i close my account
1answers
[PCB Prototype] merhaba kullanılan malzeme listesini paylaşır mısınız
merhaba kullan?lan malzeme listesini payla??r m?s?n?z
1 2 3 4 5 6 7 8 9 10 11 ...
1 PCBWay Team 5
2 Mason Goebel 1
3 Engineer 1
