Because many customers don't know the meaning of vias process on our website or choose them as default. So we always follow the gerber files to produce the vias to avoid mistake. This is our solution of vias in gerber file.
If the files is .pcb or .pcbdoc files, we will check the way of vias with the customers as we are afraid we generate the wrong gerber file.
If you can't fix the gerber files and want the result different from the gerber files ,pls make a note about the vias process you need when placing orders.
1 | PCBWay Team | 8 |
2 | Frederic | 3 |
3 | Engineer | 1 |
4 | Jegatheesan Soundrapandian | 1 |
