Hello,
I am preparing an order for 5-10 bare PCBs and would like to confirm a few manufacturing details with you before uploading Gerbers for DFM review.
Board summary:
2 layers, FR-4, 1.6 mm finished thickness
2 oz / 70 μm finished outer copper, both sides
Board outline: 177.51 × 138.26 mm
Four 3.20 mm NPTH mounting holes
No slots, castellations, edge plating, or controlled impedance
170 vias: 0.600 mm pad / 0.300 mm drill; designed annular ring 0.150 mm; aspect ratio 5.33:1
169 plated component pads; smallest annular ring 0.250 mm on three pads, then 0.300 mm on four pads
Minimum track width and copper clearance: 0.200 mm across the board
Could you please confirm the following in writing?
PTH/via copper: I need 30–50 μm hole-wall copper, with an absolute minimum of 20 μm. For the option you recommend, is this a guaranteed minimum or an average? Which IPC-6012 class applies, and how is it verified?
2 oz spacing: Can you accept 0.200 mm clearance at 2 oz finished copper? Which tier applies: Normal, Medium, or High difficulty? Please clarify whether your published values are design values or values “before compensation.”
Track width: Please confirm 0.200 mm tracks at 2 oz finished copper.
Via annular ring: Can you accept 0.150 mm annular ring with 0.600 mm pads and 0.300 mm finished drills at 2 oz? Is ring measured from finished hole or drill size? Please do not enlarge pads or add teardrops without my approval.
Component-pad annular ring: Can you accept three pads with 0.250 mm ring and four pads with 0.300 mm ring at 2 oz? If not, please state required minimum.
Drilling: Please confirm 0.300 mm finished plated holes on a 1.6 mm / 2 oz board, including finished-hole and drill-position tolerances.
Stack-up/material: Please provide the 2-layer, 1.6 mm, 2 oz stack-up: core thickness, base copper, plating, laminate brand/grade, Tg, and Dk. Does the free S1000H TG150 upgrade apply with 2 oz finished copper?
Aspect ratio: Please confirm maximum allowed aspect ratio for 0.300 mm holes at 1.6 mm board thickness.
Electrical test: Will every board receive 100% flying-probe/netlist electrical testing?
Acceptance class: Can you build and inspect this order to IPC-6012 Class 2? Is Class 3 available, and what are cost/lead-time differences?
Soldermask: At 2 oz, please confirm minimum mask dam, opening, registration tolerance, and whether 0.300 mm vias can be tented.
Silkscreen: Please state minimum legend line width and text height.
Surface finish: Please list available finishes for this build, including lead-free HASL and ENIG, with thickness ranges.
Delivery: Can you supply 5-10 individual boards, or do you require panelization for this board size?
Process tier and cost: Please state the required process tier and any additional charge.
I will upload Gerbers for DFM review after receiving your written confirmation.
Thank you,
Best regards
Davide
