I plan to put solder on a corner pad, place the chip and solder that pin, then do the rest one by one. The problem I foresee is that it's almost impossible to see bridged pins because they're mostly under the chip. I will check continuity on pins before soldering then after to help troubleshoot this potential issue. And the pin spacing is 1mm. Please tell me if you have a better idea.
1 | Nikola Krneta | 11 |
2 | Pete Dudash | 4 |
3 | Viacheslav | 3 |
4 | PCBWay Support | 2 |
5 | VinmaMat | 2 |
6 | Allianbo Guu | 1 |
7 | Ali Mohammed | 1 |
8 | Carl | 1 |
9 | Joson | 1 |
10 | Yashodha Salgado | 1 |
Your professional answers would kindly help others and you will get a reward with PCBWay Beans.
