Engineer asked Dec 05,2025
I am looking for a diy project that I can build that will let me control a set of gl Christmas lights in a sequence and that can be set to run in a loop.
I would also like for it to be connected to a computer for programming it's functions as for time on and the off as the next set of light will be turned on and off . It would be nice to be able to put it into a in closer with a random amount of a)c outlets in the in closer with a led light above each outlet to show the outlet is on or off and a way to maybe turn on and off some of the outlets if they are not in uses and I would also like to be able to expand more then one unit so that I can control more then one box at a time for more displays as I am adding them into set up even if it is connected by daisy chain them together if that is not possible then maybe a programmable memory that is built into each unit so that it can be programmed by connecting to a computer and storing its program sequence to a memory chip for timing of each outlet for switching on and off and then have it run in a loop ounce it is programed and it can be reprogrammed so if changing the display so that I can be used for about any type of project where needing a sequence of lights or machines to be cycled threw and have it so it can be set for 1 time run sequence or to be set to run in a loop and outlets can be terminated or activated if they are going to be used prefer that it have 5 to 15 outlet per unit for small displays or for large display.
If you should happen to know of a diy project that would fit the description of what I am looking for I would greatly appreciate any help on finding what it is that I am wanting to find or if you have any sujections on how I can go about building something like this it would be greatly appreciated
Thank you very much
Carl nickell
