Natanael Melchor asked Nov 07,2024
We are planning to manufacture a 6-layer PCB with your team, including both fabrication and assembly. I’m looking for a stackup similar to the one in our original design, which I’ve attached for reference. I believe your Regular #4 1.6mm stackup closely matches our requirements. However, I’d like to confirm with you if this is the best option.
Our goal is to use a standard stackup to keep costs lower. Additionally, we want to ensure that the impedance-controlled lines do not require significant adjustments, particularly in terms of width and clearance, to avoid major design changes.
Thank you in advance for your help.
